getting a frozen bolt loose--ideas?
Captain Janeway /
I'm trying to get the head off my engine to change a leaky gasket and am looking for ideas:
I just want to get the head off, but I have a choke box in the way that just won't loosen on one side. I tried an open end wrench and it started to strip corners on one of the bolts. The space there is too tight to get my socket wrench in. I'm about ready to run down to the hardware store to buy a closed head wrench, but I don't know if that will continue to strip. I already soaked it good in liquid wrench.
The only other option is getting the hoses attached to the head off, but they're not budging. There's not enough slack in them to trim them off and just reattach after.
So, any ideas on the bolt or hoses? I don't want to knock cylinder out of place because I don't want to reset the cylinder, put on new gaskets there, etc. I don't think I can wiggle the head out to change the gasket without bumping the cylinder, and I want to clean the head surface properly.
Re: getting a frozen bolt loose--ideas?
Captain Janeway /
Think I have a workable answer. Thanks.
Double Trouble Dan /
can you get a metabo with a metal wheel and cut the bolt head off?
http://www.harborfreight.com/4-12-in-angle-grinder-69645.html
Captain Janeway /
the space I need to get into is way too tight. I'm going in from another angle and cutting hoses rather than pulling the choke box. I may take a run at it when I have the head off, but the hoses are easier to replace than dealing with a broken bolt.
Thanks
simon thokaar /
Lucas Tool Box Buddy or PB Blaster work wonders. Hitting it with a torch will work wonders as well.
