Re: Puch stator coils
kim jensen /
Ground on fender should be fine, just had it off. I'll try adding another ground at the terminal. Unless the coil itself has a bad ground wire connection. I suppose I'll have to pull the flywheel next to check. What guage wire should I run back to the tail
I just ran some 16 guage, should I have used 18?
Thanks Ken!
