how do i get the condenser out of my laura m48 batavus
Randy Reddell /
So I was going to change the points and condenser on my 1977 batavus hs50, took the flywheel cover off, got the points off, but i cant figure out how the condenser is mounted on there, sorry if this is a crazy question, just dont wanna break anything. thanks
Re: how do i get the condenser out of my laura m48 batavus
♣Slew Foot♣ /
a). take the entire stator off, it is recomended to remove everything from the plate, take a microtorch heat area around condensor, use a wooden dowel and punch it out with a hammer.
b). unhook and leave there, run an external one under the ht coil.
8 out of ten you can leave the old one there hooked up and run the external w/o any problems.
Randy Reddell /
thanks! ill give this a go when i get home from work
