M1 : Bearing play in sleeve?
drunken mcfrenzy /
rebuilding this metra morini after a worn bearing, and some other issues, noticed however that the bearing sleeve has the ever slighest amount of play in it, and putting a bearing in the sleeve is WAYYY to easy, so i figured that whole side of the case is fuuuk'd.
amirite?
i got a spare set of cases to play with, just wondering if anyone else has had this problem or if i'm crazy.
Re: M1 : Bearing play in sleeve?
Typically I freeze the bearing and heat the cases and still have to press them in. something ain't right.
Overpriced Parts /
You Sure you have the right bearing?
drunken mcfrenzy /
Yes 100% sure ; c3 6203. Same bearing on other side fits snug
hmm, i need video..
\so you mean.. green loctite aka bearing retainer compound.. will take up to .020 away in some cases. most of my morinis are toast! ..
drunken mcfrenzy /
Did not know that... believe i sent ya a pm a while back mopagen about morinis actually
