suzuki fa50 brake problem.
I have a 87 Suzuki fa50 . I was replacing the tires and brake pads. I removed the rear wheel to see that the brake pad support shaft was snapped clean off. This is the part opposite of the pivot shaft. Can that be replaced? I can't tell if it's part of the casing or if it's just bolted in. I can't seem to fine that shaft/bolt online. Any help would be great.
Re: suzuki fa50 brake problem.
simon thokaar /
this site has all fa50 parts. Not sure if what you ned is replaceable tho, but they should have it.
