New Dellorto SHA 14/14 no bottom hole?
Johnny Victory /
I just ordered a new SHA 14/14 from treatland. I looked it over and when looking through the intake side of the carb there is only one hole on the brass tube. It is 2/3rd the way up the brass tube. Could this explain the lack of idle??
My old SHA 12/14 had two holes about 1/3rd and 2/3rd the way up the brass tube.
Re: New Dellorto SHA 14/14 no bottom hole?
Same exact issue here! Very interested in this
i found an one hole on a 12.12 square grande sha, 2/3 up.
bog after mods, drilled a progression hole midway between idle and the main.
hole has to be small, proceed with caution.
The idle hole goes through the aluminum body in the little recessed area where the slide sits.
