Peugeot 103 Conundrum...
Jason Komendat /
Hello! I am reaching out for help. I have a fresh ground up build. It is a 1973 Peugeot 103. When I install the drive belt and tried to pedal it, it is almost impossible, and the clutch/fly wheel do not turn. The engine turns beautifully on its own as does the rear drive train. I have checked alignment, chain tension, installed the old pulley and belt all to no avail... Is the decompression lever important even with spark plug out? Thanks in advance for ANY advice!
Jason
Re: Peugeot 103 Conundrum...
is either of your chains rusted up/frozen links?
Jason Komendat /
Actually all new. I took it out put some gas in it, pedaled hard for a little while. Everything loosened up!
Now if only it would start. Pretty hard to look for spark while pedaling...
