HELP! I cant figure out this hobbit. . . and it was going to be Edward's loaner!
So it will idle with the choke and you can ride it with the choke. . . but without the choke it dies on idle! its acting like its not getting gas. if you give it WOT before the rpms drop with the choke is off you can keep it running.
any ideas? i cleaned the carb, checked the reeds, checked for air leaks.
Maybe i missed a little passsage in the carb?
