Re: Wirng Mystery
♣Slew Foot♣ /
a bad tail light ground will blow out bulbs, so will a wonky voltage regulator box. if it don't have a resistor, under the plastic faceplate under the sockets, it is usually located in the headlight compartment attached to the terminal strip in a plstic hose. it lets your brake light dim.
