Wirng Mystery
installed my rear brake cable today now engine shuts off when I apply the brake. ON top of that I notice that the moped has a second kill switch which has one blue wire running towards the stator .
The light switch works but the stop run switch doesn't do anything . Everything is controlled by the other switch.
Headlight and Taillight works
I have a CEV 19314 taillight
Did I messed up the wiring somewhere?
what the deal with that lone blue wire going into that switch?
Re: Wirng Mystery
Also no resistor in the taillight
Re: Wirng Mystery
Dirty30 Dillon /
Your pictures are microscopic
Re: Wirng Mystery
sorry
Re: Wirng Mystery
brake light burnt out
Re: Wirng Mystery
Tm
Re: Wirng Mystery
How can I fix the brake light burning out if that the problem ?
Re: Wirng Mystery
bum pity
bump
Re: Wirng Mystery
♣Slew Foot♣ /
a bad tail light ground will blow out bulbs, so will a wonky voltage regulator box. if it don't have a resistor, under the plastic faceplate under the sockets, it is usually located in the headlight compartment attached to the terminal strip in a plstic hose. it lets your brake light dim.
Re: Wirng Mystery
Thanks ill look in the head light today .
keep you posted
