Laura m56 some issues and questions
Hallo everybody
Now it's a creat footstep for me, after ten long years i have parts, Piston and Cylinder have arrived me. But the parts doesn't fit.
My engine is not compatible with the new Cylinder. The old one is labeld with CM-48, the new with CH-30.
On foot the cylinder CM-48 is 2 mm wider then CH-30, let me explain with the first picture on the attachment
Picture 2 and 3 describes the piston seizure who killed killed the clutch ten years ago. I can't understand why the piston goes seizured..
Have anybody a solution for me, it's time to finished the project.
Thanks for attention.
Hopefully regrads
Dominik.* Moved to this forum by charliem
Re: Laura m56 some issues and questions
by the looks of the piston it had
a four corner seize.
low oil ratio
overheating engine
if rings are ok just clean piston
up with emery paper and run again
use HCL acid to clean aluminum off
of cylinder wall
wish i spoke German
Now i have some newer pictures
Picture one
Here the two ones, with the numbers CH-30, CM-48
Picture two
Cylinder with number CM-48 is 43 mm wide
Picture three
Cylinder with number CM-30 is 45 mm wide
Piston fit for both typs, without any problems. But the CM-30 will not fit for my engine :(
So i need a Cylinder with the number CM-48, new piston do i have :)
This says case needs to be bored out 1mm to fit. I don't know .https://www.treatland.tv/motomatic-batavus-M48-airsal-43-5mm-60cc-cylinder-p/motomatic-batavus-cylinder.htm. Your piston didn't look that bad.
I have order some parts here.
This cylinderhead, no comments about this.. :(
and the cylinder bore is 40 mm in both of them.
The same typ with 48ccm...
Patrick Keaton /
Use the piston that had seized,after you sand/file ruff spots to get it smooth.
If the piston rings are seized to the piston,soak in PBBlaster penetraiting lubricant in a jar for 3 weeks,then try to remove the piston rings.
