ZA50 oil drain plug question.
Hi,
I have two newly acquired Puch Za50 mopeds. One is a 1980 and the other is a 1985. When draining the transmission to inspect it I noticed the 1985 has a simple bolt as the drain plug, not like the normal drain plug on the 1980 with the O-ring. Does anyone recall a change in production in the later models where they went to a regular bolt as opposed to the O-ring style. I does seem the O-ring is there for a reason one would think.
Thanks for any help on this.
Tom
Re: ZA50 oil drain plug question.
There is a cavity higher up in the ZA's case that holds oil to keep the main shaft and output shaft bearings and gears lubed. Initially the cavity gets filled up first when you fill the fluid thru the fill hole, at which point the cavity overflows and fills the trans area. Once it's running the cavity stay filled by a groove in the top of the case that catches fluid that is flung off of theclutch bell. The tip of the drain plug seals the bottom of that cavity and provides complete draining of the cavity when the plug is removed.
Old school ZA's had the o-ring plug in which the o-ring seals the bottom of the cavity and the plug threads in to threads in the bottom of the case.
The new style simply uses a bolt that threads in to threads that are where the o-ring rested in the old style, so the threads privide the sealing of the cavity, as well as holding the plug in, as there is no threads in the very bottom of the case.
TL/DR:
Your fine. Nothing to worry about.
(edited)
Thank you for clarifying that. I had done some research but never did understand why the difference.
Tom
