Lake Saint Louis Missouri Moped Repair
$15 an hour, $30 Minimum, we contact you before we go over 30 bucks. Send a PM if you have a 2 or 4 stroke that needs repair or you just want to have us make it go faster. Thanks, Steve.
Re: Lake Saint Louis Missouri Moped Repair
$15 an hour, $30 Minimum, we contact you before we go over 30 bucks. Send a PM if you have a 2 or 4 stroke that needs repair or you just want to have us make it go faster. Thanks, Steve. (bump)
---- Corey B ---- /
Bump. Always considered opening something like this in the lancaster, PA area.
It is what I do all day anyways when I am not taking care of my baby girl. I figured I should just get paid for doing what I love. I am a stay at home dad and it is working out great so far.
$15 an hour, $30 Minimum. Send a PM if you have a 2 or 4 stroke that needs repair or you just want to have us make it go faster. Thanks, Steve. (bump)
Good pricing man... GL!
Thanks. If you are friends with the Holly Rollers Moped Gang on Facebook, I offer work @ $10 an hour instead of $15.
Already [sort of] is... up and coming at least.
Grease Bearing $15
Change Oils $10+Oil
Install Brake Pads $15+Pads
Font Fork Install $60+Fork
Handlebar Install $45+Bars
Install 50-70cc kit & Chamfer $60+Kit& Head
Crank/Bearings/Seals (rebuild) $120+Crank/Seals/Bearings
Case Matching (if needed) $30
Port Work/Chamfer $45
New Fuel Line/Filter $15 All Included
Change Tire/Tube $15+Tire/Tube
Install Exhaust $30+Exhaust
Carb Cleaning $30
Welding $60 Per 1/2 hour
Install Shocks $30+Shock
Convert to Sealed Bearings $45+Bearings/shims
Clutch/Spring Install $30+Clutch/Springs
Replace Fork Springs $45+Springs
New Headlight $15+Headlight
New Taillight $15+Taillight
New Bulb $5+Bulb
Lube all Cables $5
Cable Install $7+cable
Fix Bent Pedal $10
Timing/Clean Points $30
Install CDI + 2 Lights $60
Install CDI + All Electrical $120
Change Sprockets $30+sprocket
Hone/New Rings $30+rings
Variator Work $45+Variator
bump
Bump
$15 an hour? Are you nuts? You should quadruple that unless you have no idea what you're doing.
^^^^ Are you Jewish?
Where can I drop off my mopad for upgrades?
I usually dump my loads in your moms back yard...
