Re: Batavus clutch not engaging?
Joe Conte /
You don't have a decomp valve (or lever). The "Start" lever attaches to a spring arm that squeezes the clutch together so the engine will turn over when you pedal.
I'm not sure what your problem is. Are you able to start the motor but the clutch doesn't engage, so the bike won't move? Or are you unable to start the engine because the clutch won't engage when you pull the lever and pedal?
