Re: v1: bosch ignition - stator spark but no plug spark
Dave Davidson /
That is basically how I feel at this point, really got blue balls trying to figure out this last electrical conundrum.
Otherwise its got fresh gaskets on the top end and transmission, fresh starter plate with good pads, new rings, 15.15 SHA, MK3 pipe all mounted up, fresh cables, fuel line & filter (fuel is flowing fine - plug is wet), new fluid, gas tank is pretty well spotless on the inside with fresh gas and saber.
Checked for air leak gremlins properly with the fan assembly off before this happened, no issues there, plenty of compression
Its always a bummer when you think you got all your bases covered but really you dont.
  v1: bosch ignition - stator spark but no plug sparkTopic by: Dave Davidson Dave Davidson 08/25/14 09:10PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 09:16PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 09:20PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 09:23PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Mish Mosh Mish Mosh 08/25/14 09:23PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 09:25PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 09:32PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 09:30PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 09:33PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 09:41PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 09:43PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 09:59PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Double Trouble Dan Double Trouble Dan 08/25/14 09:45PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 10:01PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 10:15PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Anthony A Anthony A 08/25/14 10:16PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 10:22PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Dave Davidson Dave Davidson 08/25/14 10:23PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 10:25PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Anthony A Anthony A 08/25/14 10:27PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Steve Clark Steve Clark 08/25/14 10:33PM
  Re: v1: bosch ignition - stator spark but no plug sparkRe: Mo Peds Mo Peds 08/26/14 10:54AM
