oil feed pipe.
Josh Sky /
So I took off the oil injection in my streetmate r. But after a while it started to annoy me so I'm going back to oil injection. Everything works perfect but I'm not sure If the oil feed pipe is acctually putting out oil. I've been running it both with mix and the oil injection and it's not running lean. So I took off the nipple and tried to blow through it with little success. Should it be easy to blow through or what?
