Jawa Help
Would anyone know the way to install the starter pads in a Jawa I bought in pieces, 3 pad-arms and 3 springs, I am not sure how they are fixed in the housing.
Thanks Stephen
Re: Jawa Help
Kurt Fleschner /
I haven't done it myself, but have you looked at the workshop manual for the 210 at jawamoped.com? It might give you a start in the right direction.
Re: Jawa Help
adam branson /
U got the right start
the arms go on that way and direction
the springs go right there
so 1st put all arms on (place bolts back on)
then theres a trick to the spring
get piece of wire
loop it slide loop into hole after other side of spring is on
oh heck watch u tube video on easy install clutch arms
Re: Jawa Help
The spring hooks to the back of the pad arm. Then around the post. Put half of the pad arm on the post then slip the spring on and finish pad arm install.
