Clutch tuning on a Puch
Hi,
I just bought a 1986 Puch Maxi that I am having a ball with.
Did a small amount of tuning and she is running almost 30mph on the flats. Just followed the service bulletin on converting from 1.5 to 2 HP.
I do have a question. Have heard a lot about clutch tuning and, although I have searched, I cannot seem to find a good explanation on what I need to do and look for.
Any advice is greatly appreciated.
Tom
Cape Cod
Re: Clutch tuning on a Puch
Probably Fred /
You get thick springs and turn them in turns in from flush
You can grind metal away and use lighter springs .
Both make later engagement keeping you into the power at take off and on hills
Ken,
Thank you. I have been reading a lot and have seen many of your most informative postings, Thank you.
Not sure I understand what you mean by the first two sentences.
I seem like they contradict each other. Thicker springs or light springs with grinding them down accomplishes the same thing?
I thought I read that you should use weak springs and thick motor oil in the tranny but read tonight to use 0-20 synthetic.
Again thanks for any advice or help.
Tom
Probably Fred /
No grind down the metal on the shoes so you can use less spring
