Re: Seized ZA and try to set it free.
Joey Hagins /
Ken I got the studs out. Should I be able to route the crank by grabbing the cylinder and moving it? Because that doesn't seem to happen even though the cylinder seem loose from the case..
Oh a side note I can spin the front gear forward and backward even though the piston is seized as if the trans was in neutral
