Small hole sachs 505 cylinder head
I just got this Columbia with a sachs 505/1a running, and I noticed there is a little hole on the bottom of the head. It seems to be a little bit of oil and exhaust coming out of it, is this normal?
Re: Small hole sachs 505 cylinder head
It's the outlet for the decompressor valve. If your seeing smoke then the valve is leaking. You can replace it with a m10 1.5X20 bolt to bypass the decompression function and stop the leak.
Cool thanks, I didn't think it was right.
