Qt50- Does the instrument cluster come apart?
Hi, I want to separate the clear plastic from the main body. Does anyone know if these can come apart? It seems damn tight and I don't want to break either part???
Re: Qt50- Does the instrument cluster come apart?
andrew thorsen /
I think you dont want to take it off unless you dont plan to put it back on. im not sure why you would want to take it apart?
Nick, I got mine apart by freezing it and putting it into a pan with 1/2 inch of boiling water. I had to do it a couple times, but he glue joint finally started to come apart and I was able to get it off and fix it. The clear lens is glued on. This worked for me, but i had nothing to lose. Speedo was broken and I had another instrument panel with no ignition switch.
