sabre 50 1968 allstate sears
Timing , point gap ? How critical is this for starting engine? I am sure that I am close my point gap @ 0.12 to 0.16. The Timing I have moved in 16th in. increments from one way to the other.The engine sputters wont stay running.
Re: sabre 50 1968 allstate sears
Read these in order, need more help(you will, keep on posting)I think its made by Puch or am I wrong? http://www.mopedarmy.com/wiki/Fred%27s_Guide http://www.mopedarmy.com/wiki/Puch_timing
There's lee-way on that gap. It sounds to me that your main seals are dried up. Shouldn't have to split the case to replace them, but ya still gotta dig a little into the transmission to get to that one. The other's behind the stator of course.
Could be a weak coil.
Sometimes an old spark plug will fire nice when it's out, but under compression, it won't want to as much. If you have a killswitch on it, ya might check to see that it's got good new wires.
That's about all I can think of at the moment.
Overpriced Parts /
Whoa who put me in wiki without me knowing?
That page needs fixing its supposed to say 14° to 17° timing not 16-17 degrees
puch e50, z50 and za50 engine will run on 14° timing and run cooler then 16
degree timing
The Sabre has none of those motors though.
