12v Mini Maxi?
Hi, my Puch Mini Maxi keeps blowing tail light bulbs. Does anyone know if this is a 12v system? I am been putting in 6v 5W bulbs, but they blow instantly even at idle.
Re: 12v Mini Maxi?
matt boda1nz /
Get out your multimeter.
Re: 12v Mini Maxi?
matt boda1nz /
You could also try a 12 bulb.
Re: 12v Mini Maxi?
Mike Singer /
Oh man, your gonna make me measure something....I will bring a meter home from work. This has a wierd headlight bulb I can't get it out. Had no tail light with the bike, so I could not check old bulbs.
Re: 12v Mini Maxi?
Probably Fred /
You may need all the bulbs to be in otherwise you'll blow your headlight.
Some systems are that way
Re: 12v Mini Maxi?
Mike Singer /
Roff, this thing has a funky headlight bulb that is blown, maybe why my tail light is blowing? I also found this ped has a voltage regulator. Time to get the meter out for sure and see what is going on when it is running.
Re: 12v Mini Maxi?
voltage regulator could be bad. does it say 6v or12v , there's a clue.
