HELP Sputtering '80 Garelli VIP vertical motor. VIDEO
Kenneth Sanders I I /
What could be the cause of this sputtering?
Stock moped
Got this with spark, but the spark was very weak and it refused to start.
Then I replaced the points and condensor, when I did, the coil that attaches to the condensor snapped, I unwound the coil one time and then soldired it all together, no spark.
I then replaced it with a new stator plate off of a running VIP that blew its bearings, got spark and runs, but sputters.
Exhaust is not clogged, gas tank is clean, I run an inline fuel filter, has a new float needle, new plug.
I'm stumped, here's the video:
Re: HELP Sputtering '80 Garelli VIP vertical motor. VIDEO
are the points gapped correctly, .014-.018? is it timed, 23 btdc?
Ahh duh, improper timing most likely, thanks!
Is it definitely a timing issue? Second opinion anyone?
Bump
