Re: 1980 Vespa Grande, no fuel
Aimee Delin /
Okay so here is where we stand after today. I got it to start via drill starter, it won't go above 10mph even though it's a 30mph model, it sounds like it is running strong but I think it may be running rich. I say this one because it bellows out way more smoke than you would expect from a 2-stroke and also because after I manage to get it to start it will run at anything above half throttle for as long as I wish it to, but dies if brought below and refuses to start again for about a half hour.
When I cleaned the tank and petcock, the previous owner had the petcock reassembled with a hail Marry, it's scrap now, I have it kluged together with a rubber fuel line straight to the tank, my theory on why it won't idle is the carb is clogged again due to dirty fuel so tomorrow I plan to clean the carb out again.
I have made much progress from where I was a week ago, it'll run now just not steady or at max power output, where should I go from here? I am considering ordering a new carb when I order the petcock, as I have said before my knowledge on carbs is lacking, to get where I am now I am pretty happy with myself, but really just want it running. Where should I look to fix my current issues, or where is the best place to buy a new carb for it? It is a Dellorto SHA 12/12
  1980 Vespa Grande, no fuelTopic by: Aimee Delin Aimee Delin 07/30/14 09:50PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 10:30PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:50PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/30/14 10:51PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:57PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 11:15PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:24PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:25PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:26PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 07/31/14 12:13AM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 12:40AM
  Re: 1980 Vespa Grande, no fuelRe: Steve Clark Steve Clark 07/31/14 03:35AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/31/14 10:44PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:54PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 03:40AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 07:31AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:48AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:52AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 12:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 12:29PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 07/31/14 01:11PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:39PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:44PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:45PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:46PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 02:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:08PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 03:31PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:35PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:18PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:22PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 10:05PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:09PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 04:36AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/01/14 08:07AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 12:20PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 12:53PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 01:04PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 03:26PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/02/14 04:38PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 08/02/14 04:57PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:40PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:45PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:48PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:00PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:01PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 06:06PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 08:48PM
