Re: 1980 Vespa Grande, no fuel
Glenn Kuehn /
you can see the tiny hole in the casting in line with the brass tube in this pix.
the idle hole in the brass tube is smaller then the others you can see.
http://www.mopedarmy.com/mediawiki/images/2/22/SHAcarb13.JPG
there is some gearing via the pedals to help start, different then a pull start.
the three motor mount bolt holes are slotted, you have to remove the rivets from the rear one to be able to adjust the belt.
chug-chug-chug sounds good, not slipping, but may be too slow, i roll start rather then just pedal (as a good rule)
i omitted top end compression as a cause, but it would have to be really non-existant to not pull fuel.
  1980 Vespa Grande, no fuelTopic by: Aimee Delin Aimee Delin 07/30/14 09:50PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 10:30PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:50PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/30/14 10:51PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:57PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 11:15PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:24PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:25PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:26PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 07/31/14 12:13AM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 12:40AM
  Re: 1980 Vespa Grande, no fuelRe: Steve Clark Steve Clark 07/31/14 03:35AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/31/14 10:44PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:54PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 03:40AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 07:31AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:48AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:52AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 12:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 12:29PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 07/31/14 01:11PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:39PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:44PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:45PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:46PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 02:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:08PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 03:31PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:35PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:18PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:22PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 10:05PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:09PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 04:36AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/01/14 08:07AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 12:20PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 12:53PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 01:04PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 03:26PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/02/14 04:38PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 08/02/14 04:57PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:40PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:45PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:48PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:00PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:01PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 06:06PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 08:48PM
