Re: 1980 Vespa Grande, no fuel
Aimee Delin /
I did get it to fire last night spraying fuel directly into the cylinder, not sure if I will get the chance to work on it today, but this weekend I'll turn it over and make sure there is suction on the intake. If there is I'll go over the carb one last time with compressed air and cleaner, would it be possible for you to get me a picture of this easy to miss idle passage? I replaced all the jets and seals, but it sounds like the passage is in the casting which I am reusing. I have tried to start it as full choke, full throttle, and everywhere in-between and the only time I ever got it to fire was when I sprayed fuel directly into the cylinder and cranked it with a drill.
When I drill started it last night I noticed even with the drill at very low the engine turned over much quicker than when I attempted to pedal start it, the belt looks like it may be original, and while grips it does have a lot of slack, is it possible the belt it to worn and slipping rather than turning the engine over at the speed it requires? I had the carb off last night when I drill started it, so I am not sure if a high starting RPM would create the suction required to pull fuel. I distinctly hear the engine turning over when I pedal, but it's more of a chug-chug-chug (faster but you can clearly hear every compression stroke) oppose to the blending of the strokes into the buzzing sound you hear when you pull start a small two-stroke.
  1980 Vespa Grande, no fuelTopic by: Aimee Delin Aimee Delin 07/30/14 09:50PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 10:30PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:50PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/30/14 10:51PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:57PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 11:15PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:24PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:25PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:26PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 07/31/14 12:13AM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 12:40AM
  Re: 1980 Vespa Grande, no fuelRe: Steve Clark Steve Clark 07/31/14 03:35AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/31/14 10:44PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:54PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 03:40AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 07:31AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:48AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:52AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 12:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 12:29PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 07/31/14 01:11PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:39PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:44PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:45PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:46PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 02:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:08PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 03:31PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:35PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:18PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:22PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 10:05PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:09PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 04:36AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/01/14 08:07AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 12:20PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 12:53PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 01:04PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 03:26PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/02/14 04:38PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 08/02/14 04:57PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:40PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:45PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:48PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:00PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:01PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 06:06PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 08:48PM
