Re: 1980 Vespa Grande, no fuel
Aimee Delin /
At this point I am not even sure what to do with the carb, as everything seems to be in perfect working order, however the drill is a good idea, as I can now spray starter fluid through the carb while I crank the engine.
I must admit my experience with carburetors is lacking, everything is as clean as I can get it, and compressed air/carb cleaner flows through all jets and channels, but it still will not suck fuel when I am cranking, what else could be causing it to not pull up fuel from the bowl?
  1980 Vespa Grande, no fuelTopic by: Aimee Delin Aimee Delin 07/30/14 09:50PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 10:30PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:50PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/30/14 10:51PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 10:57PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/30/14 11:15PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:24PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:25PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/30/14 11:26PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 07/31/14 12:13AM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 12:40AM
  Re: 1980 Vespa Grande, no fuelRe: Steve Clark Steve Clark 07/31/14 03:35AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 07/31/14 10:44PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:54PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 03:40AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 07:31AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:48AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 11:52AM
  Re: 1980 Vespa Grande, no fuelRe: Bad Cadillac™ Bad Cadillac™ 07/31/14 12:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 12:29PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 07/31/14 01:11PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:39PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:36PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:44PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:45PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 01:42PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 01:46PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 02:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:08PM
  Re: 1980 Vespa Grande, no fuelRe: cheetahchrome . cheetahchrome . 07/31/14 03:31PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 03:35PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:18PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 04:22PM
  Re: 1980 Vespa Grande, no fuelRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 07/31/14 10:05PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 07/31/14 10:09PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 04:36AM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/01/14 08:07AM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 12:20PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/01/14 12:53PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/01/14 01:04PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 03:26PM
  Re: 1980 Vespa Grande, no fuelRe: Glenn Kuehn Glenn Kuehn 08/02/14 04:38PM
  Re: 1980 Vespa Grande, no fuelRe: Don Ohio Don Ohio 08/02/14 04:57PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:19PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:40PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 10:45PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 08/02/14 10:48PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:00PM
  Re: 1980 Vespa Grande, no fuelRe: Hugh Goldspiel Hugh Goldspiel 08/02/14 11:01PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 06:06PM
  Re: 1980 Vespa Grande, no fuelRe: Aimee Delin Aimee Delin 10/04/14 08:48PM
