Re: Honda NU50 Troubleshooting
Gruff "(OFMC)" - /
pull the sidecovers and look behind your flywheel to see if there is any oil in there/ should be dry, same for the drive side look for oil it should be dry . If there is signs of oil then that would mean your crank seals neeed to be replaced also check for....... white and grey smoke is a sign of blowby get a compression gauge and checkk it if its lower than 95 its gonna run bad should be 140+ check topend for damaged rings cly./ piston out of specs.
