Re: Replacing bearings and seals
Don Ohio /
Ben Grinev Wrote:
> So I should use a little more oil in my mix? The
> only thing I'm worried about that may possibly
> cause the problem is because of the seals facing
> the the wrong way, which wouldn't make any sense
> if that was the problem. Everything else I did
> correctly
Didn't you see how the old seals faced? They have a flat side and an open side,usually with a spring behind the lip.don-ohio (:^)
