Re: Replacing bearings and seals
Ben Grinev /
So I should use a little more oil in my mix? The only thing I'm worried about that may possibly cause the problem is because of the seals facing the the wrong way, which wouldn't make any sense if that was the problem. Everything else I did correctly
