Re: who has had a regulator fail?
Steve Clark /
They can fail and then you are in the dark but if you keep blowing bulbs you are anyway, here are two Treats has more to pick from. This is for 12v systems:https://www.treatland.tv/universal-moped-voltage-regulator-p/moped-voltage-regulator.htm This is for 6v systems https://www.treatland.tv/6-volt-voltage-regulator-p/6v-voltage-regulator.htm If your voltage is right on the bulb, 12v to match your light coil, 12v, your coil cannot produce more watts than the bulb can handle. Now if at high rpms the voltage goes up that is what will blow a bulb. your brake light may run off the spark coil going from the stator that's why it seems different. (edited)
