who has had a regulator fail?
♣Slew Foot♣ /
so what happens?
does it fail completely, or can just one circuit fail?
i am running two headlights so it doesn't blowout, here's the twist.
the tail is absolutly fine, i was getting rando surges through the headlight like some one turning on the hi beams for 2 seconds - 6 seconds randomly, it ran years like that, blew the bulb, replaced, 3 minute burn now with an extra 12v 10w halogen its steady and will only brighten with hi rpms like a downhill @ wot.
the wirings all check out fine, no bad grounds. the bulbs i suspect. i think the tomos outputs a higher wattage than the bulb can handle it's an upgraded a3 to a 70cc a35. 12v 25w bulb not enough?
even ran a meter. no big variance in voltage or amperage.
