Adjust idle Encarwi carb
New to Tomos, have an A3 with an Encarwi carb that does not have a choke or Idle screw. How does one go about tuning this bad boy?
Re: Adjust idle Encarwi carb
You don't tune it. To choke it, you press the button on the throttle and it allows the slide the drop down all the way. Then take the slack out of the cable, when you open the throttle the button will pop back and that is the idle position.
Hmmm I will have to look for this button, working on a $40 fixer upper so this all new to me. Hell to start you peddle backwards. That messed with my head for a bit. lol
And what if you don't have that button?
keep kicking it , it will start just takes longer
i'm missing the button on mine too
you adjust the idle with the barrel adjuster that on the throttle cable (edited)
