Re: Getting a 87 Trac running?
I looked at the VIN # to make sure it was an 87 and it was. When I lift up the seat there is a empty spot where the oil injection tank should be but someone had ripped it out and just went to pre-mix. I had it running last summer before this kid broke in my shed and cut all the wires. I never had the key with it I just used a flathead screw driver to turn the ignition on the on position. When I pulled it out a few days ago I put fresh premixed gas in it and cleaned the carbs and etc. And it just wouldn't turn over. Could it be because the ignition is screwed up?
