77 mopeds hobbit cdi issue
I have a hobbit with 77's cdi kit installed. The bike used to start, but it won't spark now. All the grounds are solid and I have tested continuity of all the wires. Everything looks good on that front. I spun the magneto with a drill to test the voltage coming off of all the stator wires. The wire that supplies power to the cdi box isn't showing any voltage. Any ideas? Please note that the magneto really seems to grind on the metal part of the coil mounts. Thanks.
Re: 77 mopeds hobbit cdi issue
When I got line the cdi stator coil was shorted to ground where it comes off the coil.
Remove the ground of the coil from the stator plate and check its continuity to ground, it should no longer have any (be sure the cdi is disconnected). If it still shows continuity you have a short.
Your flywheel should never touch the stator when turning.
The coil used to work, but maybe a short developed. Non of my other bikes ever had a magneto that rubbed the coil. I thought that might be an issue but I needed an extra head on this one.
Emil Kniemel /
are you using the stock ignition coil or the one that came with the CDI? im referring to the thing that sparkplug wire comes from/attached to
Using the ignition coil that came with the cdi. That shouldn't have anything to do with the fact that I'm not getting voltage from one of my stator coils.
Any volts from stator coil, one for lights?
I'm getting volts from everything but cdi power.
From Stator coil to box or not from box?
Yes. Coil to box has no juice.
Then you have a short or an open in the coil. There is no other way around it, not even suggesting that the magnets have no pull because your other coils have output. You have narrowed it down yourself just fine, why is this thread still full of speculation?
Is there a way to fix the short or open coil? This is new territory for me.
Well it looks like when it rubbed on flywheel it wiped the coil out putting a new coil won't work until you fix where it was rubbing. How did you get fly wheel off , you might have bent it.
