Re: 2001 Kinetic TFR turn signals
Maciek Dub /
Here's another couple helpful pages form the Wiki. As You can see, the black wire is just grounded to the case, so you can check voltage anywhere between the yellow wire and the frame/any ground. Follow it out, and You will be able to tell at which connection the electricity stops flowing. I'm betting it's something in the head light.
http://www.mopedarmy.com/wiki/Kinetic_CDI_Coil_and_Voltage_Regulator_Mounting
http://www.mopedarmy.com/wiki/Vespa_Kinetic_CDI
