Changing the oil seals.
Do i need to take off the crankshaft, pedals etc change oil seals or i just pull them off and put new ones?
Re: Changing the oil seals.
Yes. To do it properly you must split the case. If you're opening the engine you might as well toss in new bearings and gaskets as well and give it a good cleaning. There is a lot of info in the wiki regarding most rebuilds.
Is there temporary measure like seal it with some special silicone or something to make it run couple hundred more?
Alternatively using radiator leak stop or some other additive in oil will seal the leak?
Moped Lar (OFMC) /
NO
