Morini mo2 countershaft bushing
Christopher Jones /
I recently acquired a cosmo colt 2 with a morini mo2, and got it running noticed a sound coming from the transmission, So I drained the fluid not alot came out and started looking at things
I noticed the counter-shaft had alot of play, after further inspection I believe I need a new bushing but can't seem to find one. Is this a common issue and has anyone found a simple solution?
Re: Morini mo2 countershaft bushing
I've never worn one out,but then I've never run one without enough good,clean oil.
You can make a bushing out of copper pipe as a last resort,just leave a slight gap so oil can get in there.
Should be able to find one and match it(length not important as you can cut it) up by searching the net. don-ohio
Christopher Jones /
Thats a good idea, I could cut one out one out on the lathe at work.
Do you know if that bushing sets the thrust for the countershaft?
No,I'd have to dig out a manual or search this site for a drawing.The main thing with ANY moped tranny I've worked on is to put the shims and washers back in the same position,and the circlips also. don-ohio (:^)
