She runs kind of took the head off again made a good gasket and no more leaks she starts idles and then I take it off the stand and she starts to sputter but doesn't quit I give it throttle and it's kind of choppy through low to quarter throttle and then she kicks it in gear and scoots but at stop signs it starts to die I bring it back in back home and idles better on the stand not sure what to check or change I have an amal 15 mm with stock 45 jet do I need to change it also I know what the idle screw is on it but there's one other screw not sure what it is if someone can help with that also should I change timing it'17* retarted and doesn't get any more than 310*f carbs clean and I got a fuel filter and full tank
Sachs 505 almost perfect
