*SOLVED* Tomos Starting & Full Throttle Issue.
Simon Belmont /
Just wanted to share some personal experience, hopefully it will help someone in similar situation.
Tomos was running fine for months until one day it started having problems starting, no matter how many times you'd kick start that A35, it wouldn't start, so carburetor was cleaned & moped did start after that, but when given full throttle, the engine would stop, had to lower the throttle to engage it again, also moped was still having problems starting from 1 or 2 kicks. So the second thing I did was replaced spark plug with brand new one and tightened the 4 nuts on the A35 head (the 4 nuts inside deep holes around spark plug), that solved the problems (one of the nuts was real loose).
So to recap what was done: Carburetor was cleaned, Spark plug replaced with new one and 4 engine's head bolts were tightened.
