I'm obviously gonna have to pull er apart. Probably this weekend
After I ride it to friends garage,
So rattle in the crankcase too loud tapping noise under load.
I'm wondering if should just order piston ring, gaskets and crank bearing preemptively?
I can't make out any thing in that video. Your all over the place with the mic and it's dark as hell.
Why do you mention the piston and then say the sound is in the crankcase? Those are two separate locations. You need to study up on the proper definitions of the engine's parts to describe exactly what you are trying to get across.
dude, all I hear is an exaust leak damn...
Exhaust leak it is.
Thats the first thing I checked that night after the noise started. put my hand all around the exhaust port , felt nothing.
So today I go back out the and see a noticeable gap.
Ride to a local auto parts store on the way the exhaust swings out...
part of the exhaust bracket is missing so to Jerry rig it the previous owner must have drilled the three holes in the remaining piece and 3 holes in a washer any bolts in those holes are missing and I had to use a key ring to hold it on to get it home ...one of the exhaust bolts is missing now too.
fun fun
thanks
Dude, your still not making any sense.
Yeah I got nothin *shrug*
FA50s are super easy to work on. Just pull the jug off and see what it looks like in there... 6 bolts to remove the foot rests and 4 bolts to remove the head/jug. Then post some photos.
