Re: No spark on honda hobbit pa50II
Kevin Pierce /
leave the stock wiring if you can. check for spark by hooking the black/white wire from the coil directly to the blk/ylw wire from the stator. that should give you spark. start going through the rest of the plugs and wires to check for breaks in the wire or bad connections
