2010 streetmate R front brake caliper leaking.
Greg Salamander /
I can't tell if it is loosing pressure, but how would I go about fixing this? They Leake but they still work fine. They only Leak if I squeeze the brakes all the way down.? There leaking from inside the caliper, like where the brake disc fits inside the caliper.
Re: 2010 streetmate R front brake caliper leaking.
Never take a chance with brakes.
Just pull out the caliper and rebuild it.
If brake fluid gets on the pads and contaminates them they will not stop you when you need them most. The caliper isn't rebuildable or even worth the rebuild cost, just replace it.
Greg Salamander /
how much does it cost to rebuild it? or to buy a new one? i mean its worked fine in the past? it might now even be the caliper it might be water in the pads? how should i check?
