77' Safari Moped tail light issues
Hey so i have a 1977 safari moped and I just bought a new brake switch because the OG one lost the medal tab for the wire. When i put the new one in and hooked it up both brake lights work great when you pull the lever but i have no tail light what so ever. Wiring is fine and so is the light switch by the throttle, thoughts?
Re: 77' Safari Moped tail light issues
There should be just one brake light - you mentioned ' both.' I think you have a bad ground at your taillight if the 5 watt bulb isn't lighting up until the brake light is on.
