78 mk2 voltage surge
My 78 puch mk2 seems to have to much voltage in tail light but nowhere else. Checked with volt meter all the way back to to source didn't pull flywheel but get around 20 volts Everything looks good über the cover new in fact
Re: 78 mk2 voltage surge
Check and clean up the ground behind the tail light....
Ground is good would assume break light would be doing same for its grounded their too but will duble check light looks new so could be
