Stator key issue
Matthew Andrade /
Took my stator off and found my key on the crank to look like this is this normal this is my first moped so I wasn't sure but to meet it doesn't look right the key almost looks flush
Re: Stator key issue
looks great.
yea thats pretty normal. you dont ACTUALLY even need the thing, just helps make lining the timing up a billion times easier.
but ideally it holds no load so it can be pretty damned shallow.
the tip is pretty much what its holding onto. the arm, there the crankshaft arm, is tapered. its going down, like, a curved hill. the flywheel is straight. straight like, angles and stuff. that makes a square for it to hold onto. thats why its a moon. the other is a hill. stick them on to each other, you got a box. a square.
yea and thats about right, its so the flywheel can just stick over top of it. its gotta grab. onto something. as long as its not wobbling. (edited)
