Is this bad?
Brand new airsal and new rings never run. Leaves this streak of oil at the ring gap. Normal?
Re: Is this bad?
Probably a non issue. There is a gap there so it would make sense. Don't worry about it.
Re: Is this bad?
Thanks. Any other opinions?
Re: Is this bad?
Why do you have it assembled dry like that...no bueno
Re: Is this bad?
Yea prob just pulling oil from that puddle up top. How thick is that base gasket?
Re: Is this bad?
What do you mean by dry? I think the base gasket is like .5 mm thick
Re: Is this bad?
Brent Bublitz /
You should be using a noticeable amount of 2stroke oil on all moving bits. It keeps things safe when first starting up.
Re: Is this bad?
Yeah I'm fairly certain I have enough on there. But I'll be sure to put more on before start up
Re: Is this bad?
matt boda1nz /
I'm not sure what he's talking about in being dry.. I see the oil.
As long as you coated everything as you assembled it, you're good. But l can clearly see the oil.
Re: Is this bad? ha ha...........
Nuub kit slapping = fail.
Re: Is this bad?
Tyler Jaynes /
It's just oil passing through the ring gap, nothing to worry about
Downhill Harvey (OFMC) /
That's a hella ring gap.
