Moby Starting problems
My Moby started and ran as usual yesterday. Today, when I try to start it seems as though the clutch is not engaging. I pedal, pedal, pedal and nothing.
I have a feeling its in the variator, but no idea where to look first.
Any help appreciated.
Eric
Re: Moby Starting problems
Downhill Harvey (OFMC) /
Belt. The engine should spin easily, if the decomp is working properly.
Eric Manuel /
@ downhill harvey - I think you're right! I went out there and it started right up like 5 times, then the 6th it said no mas. I will pick up a new belt tomorrow and post the results.
Thanks
Eric
Eric Manuel /
New belt, not engaging.
Any ideas?
Is the pulley on the correct setting? Should be set to "M"
Eric Manuel /
Unfortunately it is. I started it ran last night and this morning. Now not engaging.
