Re: Tomos A3 no spark (points ignition)
Lungz ~~~ /
I still don't get what you mean. The black wire goes out of the magneto and from the wiring diagrams should be attached to the side of the coil (which is ground). From there it goes to the rest of the bike and the kill switch. Do you mean that I shouldn't connect the black wire to the coil ground? does it connect to the bottom coil instead (where the two flat head screws bolt it onto the frame)? I'm not sure I have the wires set in the right place on the coil:
http://imgur.com/w7kOKJ0
Re-cap
- I've grounded the blue wire that comes out of the magnito instead of screwing it into the terminal block, no spark
- connected the grey/green wires (that connect from the break switch to the tail lights) to close their loop, no spark
- checked the parts and they all work (0 ohm reading on multi-meter)
